It is currently Mon Nov 23, 2026 8:21 pm
PostPosted: Sun Jan 15, 2006 8:29 am
I'm looking for rod/main bearings for my upcoming engine builds. I'd really like to use Clevite/Michigan 77 bearings (0.010" under), as I've had great success with them before. Has anyone bought these recently, or have a source for them? I've tried a couple of places (Flatlander Racing is one) and they don't list numbers anymore.
Thanks much,
PostPosted: Sun Jan 15, 2006 9:03 am
Lou, I have some extra Michigan 77 rod bearings -.010. No Michigan or Cleavite mains. $15.00 a set, can bring them to Pigeon Forge. Any chance you have an extra Early "A" manual steering column and wheel? Doesn't make any difference what kind of shifter. Going to use a PB. For race car, so function is the only requirement, except cheap.
PostPosted: Sun Jan 15, 2006 12:59 pm
lou-
did a little more searching (thanks to the unc medical library!) and found some here http://www.partsamerica.com/ProductList ... set=A&so=0
good luck!
-james
PostPosted: Sun Jan 15, 2006 5:05 pm
Charlie - I will try to come up with a steering column for you and bring it to the banquet. Please bring along a set or two.
James - Thanks, I'll try PA and make sure they can still get them!
PostPosted: Mon Jan 16, 2006 9:39 am
OK, according to the PA website, they have them and two sets are on the way to me. We'll see what shows up...
