It is currently Mon Nov 23, 2026 1:02 pm
 Post subject: 2bbl idles high
PostPosted: Wed Jan 11, 2006 3:50 pm
I installed a 2bbl intake on my /6 and I can't get the idle down - It sits at about 1100 - I have sprayed carb cleaner everywhere trying to find the vacuum leak - I have turned the idle screw all the way out to no avail - I swapped back to my 1bbl and all is happy now, just no power - Any ideas?
Cheers
Adam
PostPosted: Wed Jan 11, 2006 4:22 pm
What exact carburetor did you put on your 2bbl intake?
PostPosted: Wed Jan 11, 2006 6:15 pm
An adjustment that is sometimes overlooked is the slack in the threottle cable. If you do not leave enough slack in the throttle cable adjustment then the cable will hold the throttle open.
PostPosted: Tue Jan 17, 2006 1:06 pm
I actually thought of that too until I unhooked that linkage... no dice - I tried a different baseplate as well and I can choke it off with my hands (no vac leaks) - I cannot recall which carb it was... it was a carter for sure - I used the carb that came w/ the 2bbl manifold I bought
Cheers
Adam
PostPosted: Tue Jan 17, 2006 2:30 pm
I think someone might have had the throttle plates out and didn't line them up correctly when reinstalling.........
Make sure they close all the way; if not, loosen the throttle plate screws slightly so you can get them lined up, then retighten.
PostPosted: Tue Jan 17, 2006 2:39 pm
Check for deliberately (factory) drilled holes in your throttle plates. These were present on some Carter BBD carbs, and they're calibrated for one specific engine displacement.
PostPosted: Tue Jan 17, 2006 2:57 pm
The second baseplate had those holes in them - I welded them over... no change - Have taken the plates out, switched them around every which way to no avail - Yes, I made sure they were reinstalled correctly (bevel down)
I guess the next question will be... does anyone have a good 2bbl that will work for me? - The manifold I bought is the cast iron version so there should be no cracking there :wink:
Cheers
Adam
PostPosted: Tue Jan 17, 2006 3:11 pm
Try this, run the car at idle, disconnect the throttle cable, back the idle speed screw all the way out, now back the fast idle screw out to ensure that the fast idle cam linkage is not misadjusted and the car is actually idling with the fast idle speed screw sitting on the bottom of the fast idle cam.
If the car is still idling high (actually, if it is idling at all) you have some kind of avacuum leak or mechanical bind that is allowing air to pass the throttle blades.
If the idle speed lowers when you back out the fast idle screw, you most likely need to adjust the fast idle cam linkage (or possibly the choke linkage).
