It is currently Fri Nov 29, 2024 8:47 pm
PostPosted: Thu Jan 19, 2006 9:25 pm
From all the potential problems with used manifolds and the various offerings on ebay, I'm beginning to wonder if brand new might be a better viable option. I've gathered that 1 barrel are a plenty. And the options for aftermarket are all four barrel from what I've read. Any ideas?
PostPosted: Thu Jan 19, 2006 10:03 pm
The clifford manifold can be mated either with a 2bbl or 4bbl adapter - both availible directly from clifford. Or, you can make your own out of scrap aluminum or anything else you may have laying around.
I'm not sure if offy has a 2bbl adapter availible.
PostPosted: Fri Jan 20, 2006 6:09 am
The Offy's flange is not open like the Clifford. I has four holes like the adapter. I have an Offy that someone crudely cut out the four holes to make it open. I'm going to clean up the hack work and use a MrGasket adapter so I can run a 2300 series Holley.
I don't know of any problems with the cast iron 2bbl intakes, it's the exhaust manifolds that have cracking and warping problems. Ebay 2bbl intakes go for $50-$90. There has been at least one over $100. That's insanity! If I needed one, $25 tops is all I'd give. I have two laying around my shop, maybe I need to ebay them :twisted: .
The best 2bbl intakes were the MP 1piece aluminum versions on the Super Six. They give no real HP advantage, and you are stuck with the small BBD, but they do take off 15-20lbs of front end weight. Used is the only way to get them now, it's doubtful any are still on the shelves.
Slant Cecil
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 2 guests
