It is currently Tue Nov 24, 2026 11:34 pm
PostPosted: Mon May 08, 2006 6:04 pm
On my slant the little choke housing for the carb is held on by one bolt. other one snapped at one point, it was like that when i got it. the choke is held open and doesnt work right...but my question is, not really about getting that to work because it doesnt bug me right now. but it does sound like thats where an exhaust leak is coming from.
can that housing leak exhaust? i swear its coming from right there and its pretty darn loud, and suggestions on finding my leak? any old tricks?
thanks
Daily Driver 72 'Cuda
74 Duster /6
http:www.goodysgotacuda.com
PostPosted: Mon May 08, 2006 6:42 pm
On my slant the little choke housing for the carb is held on by one bolt. can that housing leak exhaust?
Only with the '70-'72 exhaust manifolds, which have an open stove instead of a cast-in pocket.
Probably either a crack, or a faulty gasket seal at one runner.
PostPosted: Mon May 08, 2006 7:03 pm
I had the same problem on my '70. The leak was coming from between the manifold pocket and the pressed steel cup that fits under the choke mechanism (Like a rapping sound every time the 5th cylinder fired). Solution was to dig out the broken bolt and re-gasket the area between the cup and the manifold (on mine I had to drill and re-tap the hole for a bigger bolt. Cheap easy-out. What can I say?). A word to the wise, I had a difficult (impossible) time trying to find a replacement gasket, so I had to make one up. Be sure to use a gasket material suitable for exhaust applications. High-temp RTV silicone or gasket cork won't last (found that out the hard way). If your choke isn't working to begin with, another solution is to convert to a manual choke and make up a blocker plate for the hole (same gasketting instructions apply).
Nat
1970 four-door Dart, 225/A-904/2.45 gears. 0-60 in twenty three minutes!
PostPosted: Mon May 08, 2006 7:56 pm
Thanks for the info guys. Just fired the motor and poked my hand around that choke, its definately coming from that immidate area. member above said he couldnt find the gasket for that, anyone ever been able to find one or am i on my own?
74 Duster /6
PostPosted: Mon May 08, 2006 9:09 pm
Again, make sure what you're dealing with before you go parts shopping. A '60-'69 or '73-up exhaust manifold does not have a gasketed junction at the choke location—only a '70-'72 manifold does. It's possible somebody swapped a '70-'72 exhaust manifold onto your '74 car at some point, but it'd suck to go digging for a part only to find you can't use it because there's nowhere for it to fit.
Remove the choke thermostat housing from the exhaust manifold. What do you see? If you see a cast iron well, you don't have anyplace to use the mentioned gasket. If you see a hole right into the inside of the exhaust manifold, then you do have a place to put that (unavailable) gasket.
