It is currently Tue Nov 24, 2026 11:34 pm
PostPosted: Sat May 06, 2006 4:41 pm
hey there. just got a 270º/270º 111º centerline .465" lift erson cam for my slant.
wondering if these spring specs might fit this cam:
LENGTH-2.021" O.D.-1.434" I.D.-1.050" WIRE DIAMETER-0.192". Pressure: 91 lbs. at 1.650" 106 lbs. at 1.600" 183 lbs. at 1.350" 201 lbs. at 1.300" 220 lbs. at 1.250" 241 lbs. at 1.200" Coil bind at 1.110".
also have a set of brand new stock lifters to match to this cam. Do I need some special break-in procedure for solid lifters?
UPDATE: the seller says that those springs are good up to .500 lift cams. Set is around 50 bux on ebay.
Juan Ignacio Caino
PostPosted: Sun May 07, 2006 5:58 pm
If you set up the springs for 1.65 installed height, those springs will probably work for that cam. I'm not a spring expert, but from my experience, that should work, but it will be close to the edge. I think a 0.500" cam with those springs would be optimistic.
PostPosted: Sun May 07, 2006 7:25 pm
so in other words I should look for a better option? or those would work FINE? I mean, "close to the edge" doesn't sounds very "have a very nice sleep" :lol:
Juan Ignacio Caino
PostPosted: Mon May 08, 2006 6:46 am
I'm just telling you what I know, which is not a definite answer, I know. I can tell you that valve springs for a 340 mopar would work well, and I'm not sure those on ebay are as strong as a 340 spring. Look up their PN and see if they are 340 springs. 340 springs can be had very cheaply, BTW.
PostPosted: Mon May 08, 2006 3:06 pm
Thanks again lou. Do you have any P/N for 340 springs? and where can I get those 340 springs? would stocker 340 springs be good enough for millingshop free installation? or do I have to have something machined?
Juan Ignacio Caino
PostPosted: Mon May 08, 2006 5:25 pm
No machining required. Look on manciniracing.com or similar for a PN.
