It is currently Sun Nov 29, 2026 4:12 am
 Post subject: Addco Sway Bar Install
PostPosted: Wed Jan 25, 2006 1:08 pm
... for my '72 Swinger (no factory bar). I haven't installed an anti-sway bar before, but it looks pretty straight forward. I plan to support the car on ramps. Any other suggestions/advice? Thanks in advance!
VM
PostPosted: Wed Jan 25, 2006 1:36 pm
Try to find someone to beef up the mounts Addco gives you by welding them to the K-member and LCAs. Might take a little extra gusseting on the K-memb mount points. Also, you may want to locate the bar higher (relative to the Earth) on the K than the Addco mounts normally go. This saves hitting them on the ground due to less clearance.
You may have to remove the support strap between the rad support and K - can't remember for that car.
PostPosted: Sat Jan 28, 2006 11:25 am
I haven't mocked it up yet, but, looking at the lower shock bolt where the end link mounts, the strut rod is directly underneath it. It looks like it will cause interference end link. Any insight? Thanks in advance!
VM
