| Harmonic Balancer Bolt Size https://slantsix.org/forum/viewtopic.php?t=15913 |
| Author: | nate_o [ Thu Jan 26, 2006 9:09 am ] |
| Post subject: | Harmonic Balancer Bolt Size |
Does anyone know the size of the bolt that would screw into the crankshaft so you can install the harmonic balancer?? This is on an 81 slant. Thanks |
| Author: | relic-lover [ Thu Jan 26, 2006 9:45 am ] |
| Post subject: | Crank Pulley Bolt |
It is 3/4 inch diameter fine thread 1 1/4 inch long. There is a thick washer also about 1/4 inch thick. I used a clevite kit for a mopar SB. The 1 1/4 bolt would not quite pick up the threads, since my balancer would not slide onto the crank at all. I got a stack of washers and 2 longer (1 1/2 and 2 1/2 inch) bolts to help put mine on. I found later I had to remove the bolt to run my 61 170 motor. The stock 4 blade fan damn near scraps the front of the pulley. Not even enough room for the bolt head to clear the fan blades. |
