milage drop going from 2.76 -> 3.23's?
https://slantsix.org/forum/viewtopic.php?t=15934
Page 1 of 2
Author:  CrAlt [ Sat Jan 28, 2006 3:57 pm ]
Post subject:  milage drop going from 2.76 -> 3.23's?
Hey all.
I need to put disc brakes on my 72 dart but i dont want to have 2 diff bolt pattterns and i dont know anyplace that sells small bp rotors....so im gona have to put in a 8.75 rear. BUT the highest geared pig i have is 3.23's. This is a daily driver so im looking for mileage not HP. Anyone notice a big drop in milage? should i just keep my eyes peeled for a 7.25 or 8.25 with 2.76s?
Author:  Eric W [ Sat Jan 28, 2006 5:16 pm ]
I went from 2.76's to 3.23's in my '70 Fury (gone now) with a 400. It didn't really make much of a difference as is was never that great to start with. I would suspect milage wouldn't drop more than a few mpg if that. Don't forget to change the speedometer pinion gear.
Author:  Doctor Dodge [ Sat Jan 28, 2006 7:42 pm ]
you will not see any change as long as you do "mixed driving" and keep speeds under 70 mph on the open road.
If you do a lot of around town driving, a switch to 3.23 may actually improve your mileage.
Author:  65 dartman [ Sun Jan 29, 2006 5:53 am ]
Post subject:  Replacement Rotors
I bought a set of rotors at Advance Auto for the KH discs. No hub just the disc itself. You'll need to provide the hub.
Author:  dakight [ Sun Jan 29, 2006 7:07 am ]
It turns out that the KH rotors are readily available from several places at very reasonable prices.
Author:  70valiant [ Sun Jan 29, 2006 10:23 am ]
You said you are going to put disks on it but dont want 2 different bolt patterns so are going with an 8 3/4. All A-body 8 3/4 rears are small bolt pattern, unless someone else swapped in big bolt axles and brakes. if you are looking for a big bolt rear you are actually looking for an 8 1/4 rear.
Author:  Reed [ Sun Jan 29, 2006 11:28 am ]
There was a guy who used to post over on slantsix.com who owned a bright yellow duster. I think his handle was oldmopars. He swapped his duster to late style disc brakes but kept the five on four bolt pattern by ordering a pair of rotor blanks and having them drilled in the four inch pattern and having studs pressed in. Sounds like this would be way cheaper and easier than a rear axle swap.
Author:  70valiant [ Sun Jan 29, 2006 12:44 pm ]
That does sound more cost effective than $350 for new axles then having to find the right drums and other brake parts. Though swapping in an 8 3/4(or even an 8 1/4) does necessitate different U-bolts and plates as well plus shortening the driveshaft.
Author:  CrAlt [ Sun Jan 29, 2006 7:59 pm ]
I already have a rear and axles that someone cut.I think it was a C-or Bbody rear. Now that I think about it, it has the big 11" brakes on it so i cant even use the rims i was planning on using..grrr
They made no bbp 7.25's? I would rather stick with the same size axle then pay to have yet another drivesaft cut.
Author:  CrAlt [ Sun Jan 29, 2006 8:02 pm ]
Post subject:  Re: Replacement Rotors
Will the hubs off my drums work? And will it line up with the spindles and singlepistion slidder cali's on the '75 dart setup I got?
Author:  Reed [ Sun Jan 29, 2006 9:46 pm ]
Uhhhh, yes they did. 73-76 slant six a-bodies with disc brakes predominantly have 7 1/4s with the big bolt patter. It is the 8 1/4 big bolt pattern rear axle that is harder to find. BBP 7 1/4 typically can be had for $50 or less.
Author:  dakight [ Mon Jan 30, 2006 4:06 am ]
No, drum brake hubs will not work with diskbrakes; you have to replace the hub, spindle, and possibly upper control arm. If you already have parts from a 75 Dart then they are BBP hubs. If that is the case you are better off to go ahead and find a BBP rear axle.
Author:  70valiant [ Mon Jan 30, 2006 4:07 am ]
the only real advantages of an 8 3/4 over smaller rears are the greater availability of sure grips and the ease of swapping gears for racing. For a stock slant or even a mildly built street slant your best bet is a 7 1/4.
Author:  CrAlt [ Tue Jan 31, 2006 3:41 pm ]
Thats what I was asking...see the "?" :)
Its a stock slant that isnt raced or anything..just needs to run (which it does good now) and stop (which it doesnt do so good).
Thanks...a 73-76 rear is what i be needing.
Author:  imnoisydart [ Thu Feb 02, 2006 7:41 pm ]
You might want to consider the Scarebird disc conversion.
You keep the drum brake spindles, and cut off one corner I believe and then use GM rotors and calipers. There is a guy in Seattle I think who makes this setup (do a search)
The advantage is that you have new cheap brake parts as opposed to
old SBP Kelsey Hayes stuff if you can even find it.
And yes, they did make BBP 7 1/4's - I have one lying around somewhere.
Page 1 of 2 All times are UTC-08:00
