It is currently Sat Nov 21, 2026 6:26 pm
PostPosted: Tue Jan 31, 2006 9:33 pm
Hey all..
I picked up a ton of chevron delo 400 SAE 30 oil for CHEAP. I was wondering what temps this oil could be run in? Summer only? Would a slantsix care?
PostPosted: Tue Jan 31, 2006 10:29 pm
If you were intent on using it, I would say only use it in the Summer.
PostPosted: Wed Feb 01, 2006 1:26 am
This is from the 65 plymouth manual:
Multi-Grades
20w-40 where temperatures are consistently above 32F
10w-30 suitable for year long operation in many parts of the US; may be used where temperatures occasionally drop as low as -10F
5w-20 Recommended where minimum temperatures consistently are below 10F
Single Grades
30 Where temperatures consistently are above 32F
10w Where temperatures range between 32F and -10F
PostPosted: Wed Feb 01, 2006 6:14 am
Car Model: 1974 W100; 72 Dart
where are you? if in the frigid north, be careful...below the freeze line (like FLA, south TX, southern CA) use it year around.
sb
