It is currently Thu Nov 28, 2024 6:54 pm
PostPosted: Sun Jan 29, 2006 6:37 pm
Car Model: '23 T-bucket
Do either of you know of any significant pros/cons concerning aluminum pumps compared to iron pumps?
I know the alu. water pump uses bearings and a bronze bushing to support the shaft, so it seems that it should have no significant problems as compared to an iron one.
I have one (used) aluminum oil pump, and it seems to have a gear mesh problem that I think is due to wear in the housing around the input shaft.
I'd like to try to shave some weight, but not at the expense of durability.
Roger
PostPosted: Sun Jan 29, 2006 7:20 pm
Aluminum weighs less.
Factory water and oil pumps were aluminum.
