| Stock adjustable fuel pressure regulator? https://slantsix.org/forum/viewtopic.php?t=15975 |
| Author: | casedawg [ Mon Jan 30, 2006 9:09 pm ] |
| Post subject: | Stock adjustable fuel pressure regulator? |
hi all, i was wondering if anyone knows a vehicle that has an adjustable fuel pressure regulator that i could use for my efi swap. its got to be adjustable from about 30-60psi. thanks for your help. casey |
| Author: | slant6pos [ Mon Jan 30, 2006 9:21 pm ] |
225 i assume.... I think the year is pertant |
| Author: | Pierre [ Mon Jan 30, 2006 10:15 pm ] |
Your not going to find a stock vehicle with adjustable efi regulator - by the time efi came out pollution control was in full force - heck your lucky to find a stock throttle body with adjustable idle speed let alone fuel pressure Summit has a few different adjustable ones. I got mine from www.apeusa.com - its fancier, made of billiet aluminum and has a port for pressure gauge and removable fittings for whatever size you want. Costly, but the last regulator I'll ever need. |
| Author: | casedawg [ Mon Jan 30, 2006 11:03 pm ] |
if that is the case pierre, what kind of valve is a fuel regulator? i wonder if i can find one that is not necessarily automotive related. i found a bunch of good fuel pressure gages that are only 6-10 bucks instead of $30 because they're not auto related. thanks casey |
| Author: | Matt Cramer [ Tue Jan 31, 2006 6:03 am ] |
Quote: if that is the case pierre, what kind of valve is a fuel regulator? i wonder if i can find one that is not necessarily automotive related. i found a bunch of good fuel pressure gages that are only 6-10 bucks instead of $30 because they're not auto related. thanks
They're similar to a relief valve, but most industrial relief valves you'll see are heavier than a normal regulator and cost more.casey I'm just using a regulator off a Datsun 280ZX. It isn't adjustable, but it is relatively easy to install. |
| Author: | Pierre [ Tue Jan 31, 2006 1:39 pm ] |
| Post subject: | picture.... |
http://www.magnumforceracing.com/images ... akdown.jpg They are more or less all the same thing - that shows you a breakdown. The variences include capacity flow or port size and some don't have a manifold vaccum reference port (which is something you'd want anyway to drop pressrue at idle) The one I got was close to $100... summit has similar units made out of stamped steel adjustable, boost referenced, for less then half the cost. Other then fanciness, the only downside to those is that you can't rebuild them. |
