| msd coil https://slantsix.org/forum/viewtopic.php?t=15983 |
| Author: | Dustenn89 [ Tue Jan 31, 2006 5:18 pm ] |
| Post subject: | msd coil |
ok i put an msd blaster 2 coil on about 2 months ago before my rebiuld and it would not run without a ballast resistor sounds normal right well after i rebiult my engine it had to bypass the resistor and now she will run any thoughts on this is there something wrong or what |
| Author: | SlantSixDan [ Tue Jan 31, 2006 7:10 pm ] |
Remind us what kind of ignition you're running. Chrysler electronic, GM HEI, something else? |
| Author: | Dustenn89 [ Wed Feb 01, 2006 10:25 am ] |
i am using the stock 74 chrystler electronic ignition also have not yet upgraded to the oragne box so i dont know what would be going on? |
| Author: | KBB_of_TMC [ Wed Feb 01, 2006 12:04 pm ] |
| Post subject: | coil |
There isn't that much difference between the stock and orange Mopar box, and the metal can MSD coil isn't all that different from a stock coil. I've run an MSD can-type coil for years with a stock (Ford) electronic ignition w/o any problem. I have seen brand new coils that just were plain defective and wouldn't make a good spark or would arc inside and fry ignition boxes in short order. |
