| SAE 30 oil in slant? Temp ranges... https://slantsix.org/forum/viewtopic.php?t=15987 |
| Author: | CrAlt [ Tue Jan 31, 2006 9:33 pm ] |
| Post subject: | SAE 30 oil in slant? Temp ranges... |
Hey all.. I picked up a ton of chevron delo 400 SAE 30 oil for CHEAP. I was wondering what temps this oil could be run in? Summer only? Would a slantsix care? |
| Author: | Ice Titan [ Tue Jan 31, 2006 10:29 pm ] |
If you were intent on using it, I would say only use it in the Summer. |
| Author: | emsvitil [ Wed Feb 01, 2006 1:26 am ] |
| Post subject: | 65 factory service manual....... |
This is from the 65 plymouth manual: Multi-Grades 20w-40 where temperatures are consistently above 32F 10w-30 suitable for year long operation in many parts of the US; may be used where temperatures occasionally drop as low as -10F 5w-20 Recommended where minimum temperatures consistently are below 10F Single Grades 30 Where temperatures consistently are above 32F 10w Where temperatures range between 32F and -10F |
| Author: | mopar_nocar [ Wed Feb 01, 2006 6:14 am ] |
where are you? if in the frigid north, be careful...below the freeze line (like FLA, south TX, southern CA) use it year around. sb |
