| Question for Doc about Nitrous Bottle Placement https://slantsix.org/forum/viewtopic.php?t=16036 |
| Author: | imnoisydart [ Sat Feb 04, 2006 7:43 pm ] |
| Post subject: | Question for Doc about Nitrous Bottle Placement |
Doc- I know in your Dacuda you mounted the bottle where the passenger seat goes and not the normal trunk position. The car I'm building probably won't have a seat on the right either, so I could go either way. Do you recommend the "seat" position for access to controls? |
| Author: | Doctor Dodge [ Sun Feb 05, 2006 10:06 am ] |
I always mount my bottle behind the pass. seat, right where I can get to the valve. The only thing to remember is to get the special "blow-off" vent fitting on the bottle so you can screw-on a tube to vent the blow-off out of the passenger area. Tech inspectors look for that venting system any time they see a bottle mounted in the pass. area. (You reall don't want to be sitting next to a 1000+ psi NOS bottle if it blow-offs into the car) The other way to go is trunk mount with a remote valve controller but those are kind of expensive. DD |
