| Engine Tune Up. https://slantsix.org/forum/viewtopic.php?t=16106 |
| Author: | Avenger2040 [ Wed Feb 08, 2006 9:55 pm ] |
| Post subject: | Engine Tune Up. |
Ok, I´m still having problems with my car after going to electronic ignition, first thing is that after replacing dist, now I can move more easy my car in cold mornings or with cold engine. Now I got this other problem, no matter how I carburate the car and how much I move the dist, my car runs roughtly, engine shakes a lot, is worse now when I used points ignition!!!. Any help here? I need to admit that I´m a shot patience person when things don´t go the way I want. |
| Author: | Pierre [ Wed Feb 08, 2006 10:07 pm ] |
You reverse the wires on the coil or distributor? |
| Author: | Avenger2040 [ Wed Feb 08, 2006 10:22 pm ] |
I don´t whink i reversed wires to distributor, I will check wires to the coil, and double check wires to distributor. |
| Author: | Doctor Dodge [ Wed Feb 08, 2006 10:37 pm ] |
1-5-3-6-2-4 is the correct firing order. Have you adjusted the valve lash? DD |
| Author: | convx4 [ Sun Feb 12, 2006 4:35 pm ] |
I think we are having the same electronic ignition issues. My car does not idle soothly at all. When placed in drive it has a vibration. convx4@yahoo.com Bill S |
| Author: | Avenger2040 [ Sun Feb 12, 2006 4:46 pm ] |
Ok, problem solve awhile, the problem was in the carb. I just needed to fix the mix and set the engine to idle at 820-850 RPMS, also I needed to ground well the ignition module. |
