| what's the difference between these 2 intakes? https://slantsix.org/forum/viewtopic.php?t=16307 |
| Author: | TULY69VALIANT [ Fri Feb 24, 2006 10:20 am ] |
| Post subject: | what's the difference between these 2 intakes? |
I have been told to look out for a long runner, 4-barrel intake if wanting to upgrade my /6. But I came across a short runner 4-barrel. What are the differences between these two regarding performance, looks, weight, specs, etc. Thanks again in advance... |
| Author: | NewLancerMan [ Fri Feb 24, 2006 10:47 am ] |
What brand intakes are you talking about? By long runner I guess you mean Hyperpak? The short is an offenhauser, clifford or...? That way you get the best answer possible. What are you hoping to achieve with this motor? |
| Author: | TULY69VALIANT [ Fri Feb 24, 2006 11:02 am ] |
Trying to achieve durability/reliability because it will be used as a daily driver. |
| Author: | SlantSixDan [ Fri Feb 24, 2006 11:09 am ] |
Quote: Daily driver
Then a 2bbl would almost certainly better suit your needs than either of the 4bbl pieces you're asking about.
| Author: | TULY69VALIANT [ Fri Feb 24, 2006 11:21 am ] |
Any reliable brand with a good reputation that you recommend? |
| Author: | Bohmer2 [ Fri Feb 24, 2006 12:02 pm ] |
Super six intake (two barrel) with a carter BBD from a late 70's aspen/volare/diplomat. Look in the articles section off the main page all the information you need for the swap is there. |
| Author: | TULY69VALIANT [ Fri Feb 24, 2006 12:13 pm ] |
good looking out |
