hydraulic to solid lifter cam change
https://slantsix.org/forum/viewtopic.php?t=16310
Author:  mrbillohnooo [ Fri Feb 24, 2006 3:15 pm ]
Post subject:  hydraulic to solid lifter cam change
I am changing from a hydraulic to solid cam soon in my 84 daily driver pickup. Just wanting to make sure that beyond the obvious rocker arm change, there is nothing major I need to do. I am changing springs, timing chain/gears, and of course lifters. I am aware that ya need to do machine work to use a hyd. cam in a solid lifter block. If there are any passages or anything I need to block, or open up, now is the time to find out....not learn the hard way!! Any info much appreciated.
Thanks!
Bill
Author:  Charrlie_S [ Fri Feb 24, 2006 7:33 pm ]
Just use the complete solid valve train. Cam. lifters, pushrods, rocker arms and shaft.
