It is currently Fri Nov 13, 2026 6:07 am
PostPosted: Sun Mar 05, 2006 7:16 pm
Hey Dennis,
Hope all is well with you and the new combo is going together. Few questions for ya:
On your 198 rod engines, I assume you used an essentially stock head cc (58 or so)?
What did your deck height end up at? Should've been around 0.030-0.070" in the hole by my calcs, with no decking.
When you ran the MP 0.528" cam, did you need valve notches in the pistons? Any idea on valve-piston clearance you guys measured?
I'm finally putting mine together and just thinkin'...
PostPosted: Mon Mar 06, 2006 10:23 pm
The last Long Rod 225 I did had a -.020 deck height and I used a small valve notch (.040 deep) mostly for intake valve clearance.
PostPosted: Tue Mar 07, 2006 3:42 am
Lou, with no decking on the block I had -.028".
No notching required for the .528 Mopar cam.
Mike did reverse the pistons on the rods to use the factory notches with the .558 Clifford and 1.6 rockers. :shock:
I hope you end up as happy with yours as I have been with mine. :D
PostPosted: Tue Mar 07, 2006 6:09 am
Great to know, guys. I have a motor here from a guy I knew in CA that has the pistons 0.015" OUT of the hole. Might need valve notches. Probably going to run a 0.525" cam I have. Will need a stock cc head and maybe a thick gasket too.
Thanks,
PostPosted: Tue Mar 07, 2006 7:55 am
Thanks,
I know Seymour had one with the pistons at +.020" once. He had to do some relieving on the head IIRC. :shock:
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 3 guests
