| Oil pump idiot light https://slantsix.org/forum/viewtopic.php?t=16371 |
| Author: | finnman1 [ Tue Feb 28, 2006 12:36 pm ] |
| Post subject: | Oil pump idiot light |
I need to know where on my oil pump the idiot light is. Is it threaded in under the filter on the extreme left of the body? On the tip? |
| Author: | Charrlie_S [ Tue Feb 28, 2006 1:05 pm ] |
yes |
| Author: | MitchB [ Tue Feb 28, 2006 10:09 pm ] |
Don't over torque the sending unit!! You can very easily split the pump where the sender threads in if you over tighten it. Mitch |
| Author: | ValiantBoyWonder [ Tue Feb 28, 2006 10:14 pm ] |
MitchB is right, i know, i learned the hard way |
| Author: | finnman1 [ Thu Mar 02, 2006 9:52 am ] |
thanks, i just ran a line off of it to my turbo oil feed. |
| Author: | MitchB [ Thu Mar 02, 2006 10:15 am ] |
Quote: thanks, i just ran a line off of it to my turbo oil feed.
That may give you oil before it goes through the filter. I'm not sure. You do not want unfiltered oil going to your turbo.Mitch |
| Author: | Charrlie_S [ Thu Mar 02, 2006 10:33 am ] |
That location is fine. I put a "T" at that point, ran a 1/4 line from there to my turbo, and a pressure gauge line, off the other branch, and never had a problem. |
