| casting number and engine size https://slantsix.org/forum/viewtopic.php?t=16378 |
| Author: | Lehrbua [ Wed Mar 01, 2006 5:43 am ] |
| Post subject: | casting number and engine size |
HI, i am a new member from Austria (Central Europe) and have a question about the block casting number. Here the numbers, I found: 2806830 3, 09208: AAWJ W I found out, that i is an 2nd generation block with 5 freeze plugs. Can anybody tell me further details of this block? engine size? Thanks for your answers |
| Author: | Super6 [ Wed Mar 01, 2006 6:03 am ] |
If the block has not had any cleanup passes/cuts to the deck, the engine displacement should be stamped on a pad on the deck surface, on the distributor/oil pump side of the block, directly below the alternator brackets. -S/6 |
| Author: | Lehrbua [ Wed Mar 01, 2006 6:31 am ] |
Thanks! |
| Author: | Lehrbua [ Wed Mar 01, 2006 6:42 am ] |
found a interessting site where the most block casting numbers are in.year one |
| Author: | Charrlie_S [ Wed Mar 01, 2006 8:01 am ] |
Well, I se one mistake, on a quick glance. The do not show a casting number for the 198, and list it as a "G" engine family. Not! A 198 is a "RG" just like the 225. Also would need to check the numbers, to see if they show the cast crnk blocks, as being different then the forged crank blocks (they are). |
| Author: | Slant6Rat [ Wed Mar 01, 2006 8:18 pm ] |
Heres a list I've had bookmarked. It shows your number as a 68-70(also the RG series) Cast and forged block numbers are shown. http://www.autohobbydigest.com/tables.p ... ng-Numbers |
