| Aluminum 2 Barrel Intake https://slantsix.org/forum/viewtopic.php?t=16381 |
| Author: | duke76 [ Wed Mar 01, 2006 9:03 am ] |
| Post subject: | Aluminum 2 Barrel Intake |
I have one of those 2 piece aluminum intakes that has holes where the welds are. I was wondering if anyone has ever tried to fill these holes with an epoxy and been successful. I really want an aluminum, but can't seem to find the one piece within my price range. I bought some of that POR 15 epoxy and was going to try to fill the holes with that. |
| Author: | mopar_nocar [ Wed Mar 01, 2006 10:52 am ] |
| Post subject: | V8 |
i have fixed V8 intake manifolds with JB weld succesfully. make sure everything is CLEAN CLEAN CLEAN before you start. sb |
| Author: | Slant6Ram [ Wed Mar 01, 2006 11:11 am ] |
| Post subject: | Holes? |
Those old aluminum manifolds may look bad, but not even leak. My Aspen has no problems with the stock 2 piece welded aluminum super intake. Did you test yours? or are you simply guessing that it will leak based on appearance. I think that JB weld sounds safe for holes, but might not work on a crack. Read the label, What ever you use must stand up to slightly hotter than boiling temps and be resistant to gasoline when cured. I think the worries about leaking aluminum manifold seams has been overstated by guys on ebay trying to unload cast iron manifolds without getting too much gripe about shipping. |
