Specs
https://slantsix.org/forum/viewtopic.php?t=16399
Page 1 of 1
Author:  ROADRUNNER7169 [ Thu Mar 02, 2006 6:10 am ]
Post subject:  Specs
hello does anyone know all the torque specs for all the bolts in the 7 1/4 rear on a 74 dodge dart (2.76 case with roll pin 9 bolt cover)
thanks
Dustin
Author:  Dennis Weaver [ Thu Mar 02, 2006 7:05 am ]
Cap bolts:...........................40 ft/lbs.
Ring gear bolts:...................55 ft/lbs. (L/H thread)
Pinion flange nut:.................210 ft/lbs (min)
Cover bolts:........................250 in/lbs.
Axle retainer nuts:...............35 ft/lbs.
Driveshaft (U-joint) bolts:.....15 ft/lbs.
D/W
