| 904 Rag change and "tune" https://slantsix.org/forum/viewtopic.php?t=16421 |
| Author: | Brucehockensmith [ Fri Mar 03, 2006 4:54 pm ] |
| Post subject: | 904 Rag change and "tune" |
I'm about to do a trans.filter and fluid change on the wagon and the Ebooger cheapie tuneup. I've done this several times in the past to other cars/trucks of mine but it's been some time ago. With the past two years of hurricane reshuffling of my files I can't find the copy of that Mopar Action article. I know that the acumulator spring is removed , The 1-2 line pressure @the valve body is turned up and the fluid is changed to type F (I do not do the fluid change). I keep thinking there is one more step but my memory fails (a lot) ..... Does anyone have said copy or remember the steps?? |
| Author: | james longhurst [ Sun Mar 05, 2006 5:10 am ] |
bruce- i have the august 2000 issue right here and the three items you mentioned are pretty much it. it's a good idea to pull the accumumator piston out and insert a steel rod behind it to keep it from moving. the only other thing i'd do is adjust the bands while you're there. i could scan the article and email it to you if you like. -james |
