It is currently Sun Nov 08, 2026 8:40 pm
 Post subject: What is this?
PostPosted: Thu Mar 02, 2006 11:25 am
What is the little plug bolt that is located about 5 inches below the 5th and 6th plugs on the distributor side of the engine? Is it a place to put an oil pressure sending unit? Or maybe for a temp sensor? I'm at work and don't have any pictures of that side of the engine, so I made this really craptastic mspaint to illustrate what I'm talking about.
http://i9.photobucket.com/albums/a75/ja ... k1/meh.jpg
64 Dart 170 /6
PostPosted: Thu Mar 02, 2006 11:40 am
Sounds like the drain plug for the water jacket.
 Post subject: Yep...
PostPosted: Thu Mar 02, 2006 2:08 pm
Tht would be the correct answer, and you might need a coat hangar to clear it if the engine has been around a long time....
PostPosted: Thu Mar 02, 2006 2:12 pm
IIRC, on older blocks there is a plug in the oil galley where they used to put the oil pressure sender.
PostPosted: Thu Mar 02, 2006 2:42 pm
Thanks for the info.
Is '64 an "older block"? If so, it would be nice to put an oil pressure sender in there, but for some reason I am loath to just remove it and see what happens.
-josh
64 Dart 170 /6
PostPosted: Fri Mar 03, 2006 7:34 am
Yes, but that plug is not in the location asked about.
Your '64 would have originally had the oil pressure sender in the oil gallery/block location. A 1965 Technical Service Bulletin recommended moving the sender back to its '60-'63 and '65-up location on the oil pump to obtain more accurate and faster oil pressure readings. There's no benefit to the block location for the sender.
