| Accelerator cable length https://slantsix.org/forum/viewtopic.php?t=16422 |
| Author: | Jeb [ Fri Mar 03, 2006 5:10 pm ] |
| Post subject: | Accelerator cable length |
Could somebody tell me the length of the supersix throttle cable? I am thinking about getting one the stainless steel throttle cable kits instead of digging through a junkyard. Also, with Lokar's kickdown cable for the 904 TQ, will I have to change the lever on the side of my transmission? Or does it just bolt right on and come with its own lever? |
| Author: | Pierre [ Fri Mar 03, 2006 5:38 pm ] |
| Post subject: | Re: Accelerator cable length |
Quote: Also, with Lokar's kickdown cable for the 904 TQ, will I have to change the lever on the side of my transmission? Or does it just bolt right on and come with its own lever?
You remove the pin that holds the stock linkage to the lever. Then on the end of the lokar cable theres a stud that goes through the lever then nut on the other end that holds it to the lever. The lever itself stays on the transmission.
