It is currently Sun Nov 15, 2026 8:33 am
 Post subject: Great carb alternative
PostPosted: Sat Mar 04, 2006 2:00 pm
I'm using a solex staged 2 bbl, great little carb, all modular design, you can change and machine to your specs the boosters, the venturis, emulsion tubes, air bleeds, jets, idle circuit restriction and bleeds.... I'm loving it! better than holley adjust-a-s h i t :lol:
I don't know if you guys have those carbs up there... as usual they're licensed and produced by argelite s.a. (argentinian manufacturers of licensed holleys, webers, solex, etc)
I'm using a 36-36 mm staged 2 bbl on my supersix intake.
I'm beggining to prepare my dual 1 bbl intake for using 2 32-34 staged (where the 32 mm barrel is the primary)
all have mech secondaries if staged
these come in this flavors
Staged:
26-38 (hard 2 get)
32-34
34-34
34-36
36-36
non-staged (the 2 throttle blades open @ same time)
34-34
36-36
40-40
These are nearly as dependable and nice as carter BBD (but I can get all the new parts I want down here... you're lucky if you can find a carter bbd gaskets set @ local speed shops or parts store)
Juan Ignacio Caino
 Post subject: Btw...
PostPosted: Sat Mar 04, 2006 2:02 pm
Yes, D/W
I'm sick of holleys :lol:
Juan Ignacio Caino
PostPosted: Sat Mar 04, 2006 2:25 pm
Looks like you are the only one who can get that carb, got pics?
Mopar Muscle is well defend by Slant Six!
Valiant Duster 1971
PostPosted: Sat Mar 04, 2006 3:19 pm
Pictures! We wanna see pictures! :-D
PostPosted: Sat Mar 04, 2006 3:31 pm
Does it look like this?
PostPosted: Sat Mar 04, 2006 5:19 pm
kindof, but bigger :lol:
No, that's a 34 EIES, mine is a 34 TEIE
I'll take some pix before installing it. I have to do some trick adapter because holes share sort of the same size... closer enough to make the fabrication of an adapter complicated but diffrent enough to not being able to butcher carb's body and get away with no modification
other great advantages that I forgot to mention:
you don't need throttle return spring. It has 3 springs stiff enough and reliable enough to forget about springs. And the 2 barrels opens towards the center so fuel distribution is greatly improved.
You can get electric chokes or coolant activated chokes, and there's a fancy device that cuts off the idle feed when you cut the ignition. I didn't get all those fancy add ons, I like my carbs simple and I don't like electric devices anywhere near the carb
when float closes the needle, you have an extra connection that sends back the excess of fuel
ain't have no metering block/s. the carbs' body contains all the pasages, fuel bowl cover is ontop the carb so you ain't get leaks,
emulsion tubes, bleeds, fuel jets comes in fancy metric steps. ie main fuel jet #145 would be 1.45 mm ( say #58) and decreases and increases in .05 mm steps. great fuel curve tailorage capability. air jets and idle assy are stamped the same as jets
fuel jets are almost on the bottom of the bowl, so cornering, hard acceleration oand braking issues are minimized
fuel bowl is rather small so the fuel pump doesn't sees long free flow/restricted flow & overpressure cycles
both barrels have separated idle adjustment
idle and transition circuits are independent as well.
throttle lever is very slant friendly. practically a 1920 or BBS bolt on replacement... if you have lokar or other cable kickdown :wink: but adapting a "normal" KD would be minor fab
accel pump nozzle (only on primary barrel) and all the accel pump mechanism is extremely sensitive, and works very well under various throttle position /pressures
Does have its drawbacks: no PCV provision, parts are very warpage prone (much like BBS, wich can be easily adressed by not allowing Godzilla to tinker with your carb... hehe) and mostly the adapter thing
It has many of the weber style advantages but w/o the price or the weber hassle (I hate them) I mean, great tuneability and almost infinite tailorage chances, and once you set it up no need to be fiddling around twice a day like Holleys.
Juan Ignacio Caino
PostPosted: Sun Mar 05, 2006 2:20 pm
here are some pix
Juan Ignacio Caino
PostPosted: Sun Mar 05, 2006 2:46 pm
Yeah, it is bigger :P
Let us know how it works!
PostPosted: Sun Mar 05, 2006 3:05 pm
What can you find in the way of air cleaners for it?
PostPosted: Sun Mar 05, 2006 6:39 pm
that's the million dollar question :lol:
I gotta find some options for this. mostly it would be: unsilenced open element, silenced, and the "modern" stuff wich has kind of a rubber snorkle and a tall but small diameter filter, like present cars.
Juan Ignacio Caino
PostPosted: Sun Mar 05, 2006 6:47 pm
VW guys are big into solex-es. Check out Ebay for a sampling.
$25 air cleaner: http://cgi.ebay.com/ebaymotors/VW-EMPI- ... 1659QQrdZ1
PostPosted: Sun Mar 05, 2006 7:17 pm
I don't consider that an air cleaner.
Here, by the way, is the ebay string I have assigned to a "hot key": I just hit the hot key, the string gets typed for me, then all I have to do is paste the ebay item number on the end. It bypasses all the nonsense ebay's been doing lately with all the description words and extra characters in the URL:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=
PostPosted: Mon Mar 06, 2006 3:04 am
lotsa pix but not the one I wanna see: the carb side mounting flange... and I wonder if it fits my app.... solex name is only on the title, then when you read all the applications it fits you see only weber and dellorto (wich in plain english means litterally "from the a s s" hehehe that's some carb I won't be installing :lol: )
Juan Ignacio Caino
PostPosted: Mon Mar 06, 2006 10:34 am
So, who used these carbs? peugeot???
Or is it an aftermarket piece?
PostPosted: Mon Mar 06, 2006 11:35 am
How would this compare to the Holley/Weber 5200 progressive two-barrel?
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 4 guests
