What 2bbl carb would you run?
https://slantsix.org/forum/viewtopic.php?t=16515
Page 1 of 1
Author:  olddaddy [ Sat Mar 11, 2006 3:55 pm ]
Post subject:  What 2bbl carb would you run?
I've got a 225 slant/6 out of a 72 Dart. I have a cast iron super six setup and wondered what 2bbl carb would be best to run? My car is a 50 Plymouth, so I'm not worried about originality or correctness. I want something simple, no smogs or anything. Engine is basically stock, bored .030, electronic ignition, stock exhaust with 2" pipe, 904 automatic.
Author:  Jeb [ Sat Mar 11, 2006 5:45 pm ]
Carter BBD definitely. Easy to tune, reliable, good design and has an excellent metering sytem. One of the best 2-barrels ever made. Be soure to check for throttle shaft wear. That can be corrected by having the throttle shaft rebushed.
Author:  FrankRaso [ Tue Mar 14, 2006 6:52 am ]
If I had a super six intake kicking around and was looking for some 2bbl carb ideas, I would probably try something like what OZZ did. I haven’t had any experience with Webers yet but I’ve heard they’re great carbs.
Have a look at the following installation of OZZ's posting on SS.com
More photos of Weber installation at OZZ's cardomain site
Frank
http://cars.rasoenterprises.com/
