| 10" front drum (66) replacing https://slantsix.org/forum/viewtopic.php?t=16539 |
| Author: | sixsignet [ Mon Mar 13, 2006 1:33 pm ] |
| Post subject: | 10" front drum (66) replacing |
When you order a new front drum for a 66, do they come with the hub attached or do you need to have it mounted on a hub? |
| Author: | HyperValiant [ Mon Mar 13, 2006 7:33 pm ] |
Im 99% percent sure all you get is the drum,I know thats all you get with the 9 inch drum. Be careful removing the drum from the studs because they are swagged on from the front.I ended up grinding the heads off the studs from the back and driving them out the front of the drum and installing new studs. HyperValiant |
