| 66 b'cuda v8 to slant swap?? https://slantsix.org/forum/viewtopic.php?t=16573 |
| Author: | featherduster76 [ Wed Mar 15, 2006 1:30 pm ] |
| Post subject: | 66 b'cuda v8 to slant swap?? |
Yea I know its weird but I recently acquired a '66 barracuda that was a drag car, really cheap too. It has no motor or tranny but it was a factory 273 car and Id like to put my slant 6 in it. But would I have to swap k members to do this?? You can laugh now.... and would be very competitive |
| Author: | 65 dartman [ Wed Mar 15, 2006 1:34 pm ] |
You're in luck - the K Frame is the same whether for a 6 or 8. You must use the 6 mounts - I'm just not sure whether they are 63-66 specific or can use the 67-72 mounts |
| Author: | GuyLR [ Wed Mar 15, 2006 2:39 pm ] |
AND you get all the good V8 stuff like the 10 inch brakes, ball bearing steering gear unit, 5 leaf rear springs, heavier T-bars and a stronger rear axle. Do it! |
| Author: | Charrlie_S [ Wed Mar 15, 2006 2:47 pm ] |
You will need the 63-66 "A" body, slant six engine brackets, insulators (mounts), oil pan and pickup. Any year engine and matching trans will work. |
| Author: | dookdart [ Wed Mar 15, 2006 4:37 pm ] |
I'm pulling a good running 198 from my 64. If you want some parts.....let me know. Mike |
| Author: | featherduster76 [ Wed Apr 05, 2006 12:53 pm ] |
GuyLR wrote: AND you get all the good V8 stuff like the 10 inch brakes, ball bearing steering gear unit, 5 leaf rear springs, heavier T-bars and a stronger rear axle. Do it! Well The 5 leaf rear springs are nice but the previous owners set it up for a narrowed rear, already complete w/tubs! |
| Author: | mcnoople [ Wed Apr 05, 2006 1:22 pm ] |
Just wondering what makes you think it started life with a 273 if nothing is original. |
| Author: | featherduster76 [ Wed Apr 05, 2006 1:31 pm ] |
mcnoople wrote: Just wondering what makes you think it started life with a 273 if nothing is original.. Well the car still has it's original vin plate which denotes a 273V8 and the v8 emblem on the fender It's not very shiny or pristine but if anyone wants to check it out see my '71 Duster gallery |
| Author: | Reed [ Wed Apr 05, 2006 1:35 pm ] |
You lucky bastard! |
| Author: | featherduster76 [ Wed Apr 05, 2006 6:14 pm ] |
Reed wrote: You lucky bastard! Ummm... Thanks |
| Author: | Reed [ Wed Apr 05, 2006 9:14 pm ] |
I struggled for several years to restore/modify a 66 barracuda formula "s" that I eventually had to give up on due to extensive body damage. |
| Author: | Charrlie_S [ Thu Apr 06, 2006 4:51 am ] |
You mean, my slant powered 66 Cuda will have a friend at Wilkesborro? |
| Author: | featherduster76 [ Thu Apr 06, 2006 12:39 pm ] |
Charrlie_S wrote: You mean, my slant powered 66 Cuda will have a friend at Wilkesborro? Well Glad to hear you'll be bringing it back. All the slant gang will be seeing it, but it might be a while |
