| cam timing marks https://slantsix.org/forum/viewtopic.php?t=16574 |
| Author: | finnman1 [ Wed Mar 15, 2006 3:20 pm ] |
| Post subject: | cam timing marks |
new motor all hooked up and ready to go, no start. compression is around 40 for each cylinder. i suspect the cam was installed incorrectly. engine puffs but won't take off and run. when installing the cam, the arrow on the cam gear lines up with the " 0 " on the crank gear right? the only marks i could find one the crank gear were some letters and the "0" symbol. (stock cam) i didn't degree the cam in, but i don't think it would affect enough to not start. i dunno, maybe it's the coil?? good spark though. |
| Author: | Dustenn89 [ Wed Mar 15, 2006 3:27 pm ] |
sounds like your timing is off a little have you tried moving the distributor while someone crank? i didnt degree in my stock cam, lined up with timing chain marks(gears rather) dot to dot |
| Author: | finnman1 [ Thu Mar 16, 2006 12:44 pm ] |
so it is the little 0? the arrow lines up with? |
