| Using a Power MC as a Non-Power MC https://slantsix.org/forum/viewtopic.php?t=16626 |
| Author: | DART68 [ Sat Mar 18, 2006 12:33 pm ] |
| Post subject: | Using a Power MC as a Non-Power MC |
In Tom Condran's "Performance and Handling for classic Mopars" book, he recommends using a '73-76 MC from a power set-up as a non-power set-up. I know about the push rod retaining issue. Are there any other issues I should worry about? Thanks-Dart68 |
| Author: | SlantSixDan [ Sat Mar 18, 2006 12:46 pm ] |
Choose your master cylinder by piston/bore diameter, and configuration/physical compatibility, not by "power vs. manual". The master cylinder generally doesn't know whether it's bolted onto a booster or straight onto the firewall. About the only special issue to be aware of: There's a random mix of good info and nonsense in Condran's book. |
| Author: | sixsignet [ Sun Mar 19, 2006 3:34 pm ] |
Since I am about to start my first front end rebuild, and I am using Condran's book as a guide, what parts are nonsense? |
| Author: | SlantSixDan [ Sun Mar 19, 2006 7:52 pm ] |
Oog. I'm not up for a page-by-page critique. Just post the ideas you're thinking of following or the info you're thinking of using here on the board, and you'll get plenty of opinions on the matter. |
| Author: | emsvitil [ Sun Mar 19, 2006 10:19 pm ] |
I haven't read (or have) Condran's book, but probably have read similiar types of books. In general, I NEVER use 1 book as gospel. I use various sources (including here) to get an idea of how things work, what may be possible, and even what may be a really stupid idea............ Then I'll decide to do something (or not do something) |
