It is currently Wed Nov 18, 2026 11:00 am
 Post subject: Viscous Fan Assembly
PostPosted: Fri Mar 24, 2006 4:54 am
I just bought a new viscous fan assembly (fan and clutch). The clutch is pretty hard to turn. Is that normal?
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Fri Mar 24, 2006 6:04 am
Yep, that's how it is supposed to be.
PostPosted: Sun Mar 26, 2006 9:55 pm
The Viscous Fan fits slant sixes? When I talked to a guy at summit, he said that they would only fit v8s.
Cory
-'72 Valiant Sedan, Stock (For Now)
PostPosted: Mon Mar 27, 2006 4:44 am
They will fit if you have enough room between the water pump and radiator. Early a-bodies are very limited in that respect. Clearance is so tight that one of the most common sights is a ring of damage in the radiator fins where the fan has contacted the radiator. If the motor mounts are not in very good condition even hard braking can pitch the engine forward into the radiator. In fact, I'm seriously consodering (here it comes Dennis) some polyurethane engine mounts for mine.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Mon Mar 27, 2006 4:45 am
They will fit the engine, but on many cars will not fit between the radiater and water pump.
PostPosted: Mon Mar 27, 2006 11:41 am
I looked high and low for polyurethane motor mounts and no body had them for a spool type /6. They also coundn't say if the small block mounts would work.
PostPosted: Mon Mar 27, 2006 11:02 pm
Do you think a viscous fan assembly would fit in my '72 Val.? How much clearance do you need?
Cory
Users browsing this forum: Google [Bot] and 9 guests
