It is currently Wed Nov 18, 2026 7:20 am
 Post subject: oil pressure
PostPosted: Mon Mar 27, 2006 9:41 pm
Wow... finally got everything all bolted up on this engine swap except for the carb. figured I'd take that opportunity to crank the engine and make sure I was getting oil pressure.
Well, after cranking it intermittently for a couple minutes, I don't. Tomorrow I'm gonna take the cover off the oil pump and put some vaseline in there... (right now there's just a light coating of liquid wrench). If it's not that, all I can figure is that the gear I put on it has started spinning on the shaft, though I wouldn't think so. (pump is a new melling; pulled the gear off the old pump and put it on the new pump before installing it.)
If the vaseline doesn't fix it, I guess I'll swap in the new pump I ordered today, and leave the gear on it that came on it (as much as I hate to do that).
PostPosted: Tue Mar 28, 2006 4:44 am
I always pack the oil pump with light grease before installing it. That's a trick I learned at my first wrenching job.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
Users browsing this forum: Amazon [Bot] and 4 guests
