| Problem with KH Dust boot mounting https://slantsix.org/forum/viewtopic.php?t=16748 |
| Author: | NewLancerMan [ Mon Mar 27, 2006 9:30 am ] |
| Post subject: | Problem with KH Dust boot mounting |
In the process of rebuilding my calipers, I noticed a small dent that looks like it was caused by a chisel or something. It deforms the dust boot seal just enough to force it to push into the piston more than it should. I am worried it will hang the piston up (it was hard to install, and harder still to get back out. Picture 1: http://tinyurl.com/ktz9o When I removed the boot, here's what I saw: Picture 2: http://tinyurl.com/k7m4f The question is, should I try and use a thin flap disc on a dremel to remove the material that is dented downwards to make this seal up correctly? I'm not sure what to try or what tool to use. Being cast, I can't see bending it very easily without deforming something else. Thanks! Menko |
| Author: | SlantSixDan [ Mon Mar 27, 2006 9:32 am ] |
Yep, your Dremel idea will work fine. Just proceed carefully. |
| Author: | NewLancerMan [ Mon Mar 27, 2006 9:35 am ] |
ok just wanted to be sure I wasn't fooooooobar! Off to try |
| Author: | dakight [ Mon Mar 27, 2006 5:14 pm ] |
Quote: ok just wanted to be sure I wasn't fooooooobar!
Well.... now that's an entirely different question... |
| Author: | NewLancerMan [ Mon Mar 27, 2006 8:34 pm ] |
Yeah the true colors appear quickly don't they MJ |
