| oil pressure https://slantsix.org/forum/viewtopic.php?t=16764 |
| Author: | CStryker [ Mon Mar 27, 2006 9:41 pm ] |
| Post subject: | oil pressure |
Wow... finally got everything all bolted up on this engine swap except for the carb. figured I'd take that opportunity to crank the engine and make sure I was getting oil pressure. Well, after cranking it intermittently for a couple minutes, I don't. Tomorrow I'm gonna take the cover off the oil pump and put some vaseline in there... (right now there's just a light coating of liquid wrench). If it's not that, all I can figure is that the gear I put on it has started spinning on the shaft, though I wouldn't think so. (pump is a new melling; pulled the gear off the old pump and put it on the new pump before installing it.) If the vaseline doesn't fix it, I guess I'll swap in the new pump I ordered today, and leave the gear on it that came on it (as much as I hate to do that). |
| Author: | dakight [ Tue Mar 28, 2006 4:44 am ] |
I always pack the oil pump with light grease before installing it. That's a trick I learned at my first wrenching job. |
