swapping rearend in f-body
https://slantsix.org/forum/viewtopic.php?t=16817
Page 1 of 1
Author:  volare320hp [ Thu Mar 30, 2006 9:19 pm ]
Post subject:  swapping rearend in f-body
I'm wanting to swap the rearend in my f-body. I think that I have a 7 1/4 and i want at least an 8 1/4. I'm not sure what to pull it from. :evil:
Author:  volaredon [ Mon Apr 03, 2006 6:46 am ]
Diplomat, Gr. fury (cop cars!) are a direct bolt in and they made em all the way to '89! A 5th ave is also a direct swap but most of those I see have the same crappy 7-1/4 that you are trying to get away from. 80-83 Mirada or Cordoba also direct swap. If you get to a JY, take a tape measure and check Cherokees and Dakotas (although if you go Dakota youll have to stay between 87-90 unless you want 6 lug axles!) These would at a minimum need the perches cut off ane rewelded.
Author:  Jeb [ Mon Apr 03, 2006 9:27 am ]
Most of the M-bodie cars came with a 2.25 rear axle ratio. A few cop cars got 2.93's.
Author:  Wm. Moore [ Sat Apr 29, 2006 9:36 pm ]
A cop car will almost always have the 8.25 axle in 2.9 ratio, and often with sure grip. Will also have bigger brakes, rear sway bar, heavy duty springs and rear shackles. Wagons almost always have the 8.25, usually in 2.4 past 1980. I have seen a 2.2 in a wagon, but that is not common. If you find a cop car, get the front sway bar as well, as it is bigger, 1.125 vice 1.0 for most F, M, J body cars. Performance suspension sells the bushing kits to mount the bigger bar.
The 2.2 ratio started around 1980, same year that the 904 tranny went to the lower first and second gears.
Author:  mikeysmopar [ Sun Apr 30, 2006 6:08 am ]
Post subject:  rear end
This what i did i put a 8-3/4 out of a b body in my aspen, had to grind the spring perch loose move them in about 1/2 inch and set the pinion angle make sure that it is centered then weld it together. :D
