| Cam help? https://slantsix.org/forum/viewtopic.php?t=16853 |
| Author: | GTS225 [ Sun Apr 02, 2006 3:25 pm ] |
| Post subject: | Cam help? |
Looking at these two on Summit website. http://store.summitracing.com/Compare.a ... RS-E470521 Anybody care to comment for a 2000-2400 pound car, 225 and two-barrel, auto trans? Roger |
| Author: | emsvitil [ Sun Apr 02, 2006 3:59 pm ] |
Your link doesn't work. (goes to summit, but doesn't compare anything) What 2 part numbers are you comparing? |
| Author: | GTS225 [ Sun Apr 02, 2006 6:34 pm ] |
Hmmmmm......Must need a cookie from Summit for it to hook up for anybody else. Here; ERS-E470621, and ERS-E470302. Both of them are Erson cams. One is touted to be for 2000-5000 rpm, while the other has a bit more duration, but same lift. Roger |
| Author: | emsvitil [ Sun Apr 02, 2006 7:50 pm ] |
I'd go for the ERS-E470301 because you have an automatic transmission............. Unless you're going to be manually shifting the automatic, the transmission shift points are more suited for the lower rpm range.......... |
