It is currently Tue Nov 24, 2026 11:59 pm
 Post subject: Caliper location
PostPosted: Mon May 08, 2006 5:53 pm
Simple question.
Are the brake calipers of the F-Body (Volare/Aspen) located on the forward side of the rotor or on the rear?
Thanks
PostPosted: Mon May 08, 2006 6:31 pm
on my car i put them in the rear. it is possible to put them in the front if you swap the spindles side to side. with the calipers in the front you might have clearance problems with the sway bar if you have one. i don't know what effect having the calipers in the front would have on braking performance. maybe others will chime in and let us know.
zedpapa
1970 dodge dart w/225 /6 bored .040" over, holley 390cfm w/vac. sec., compcams 252s, clifford shorty headers w/2.5" exhaust w/flowmaster, f-body 11" front discs, aluminum A-833OD, 8 1/4 w/3.21 SG
soon to have 5 gears!!!
PostPosted: Mon May 08, 2006 8:09 pm
Factory they are to the back.
 Post subject: Thanks
PostPosted: Tue May 09, 2006 3:39 am
Thanks,
I was looking for the factory location,
Rick
