| One more question about 4 pin module https://slantsix.org/forum/viewtopic.php?t=16887 |
| Author: | valiantboy_66 [ Mon Apr 03, 2006 7:15 pm ] |
| Post subject: | One more question about 4 pin module |
I am going to run a MSD 6AL with with this GM module set up. What wire configuration should I buy? Mopar or GM? |
| Author: | Charrlie_S [ Mon Apr 03, 2006 7:30 pm ] |
Neither. Use the mopar electronic distributor, and the MSD wireing, diagram. You do not need any other components, except for a compatable coil. |
| Author: | valiantboy_66 [ Mon Apr 03, 2006 8:44 pm ] |
Thanks, Charlie I thought you needed a module even with MSD. So as an upgrade I would use a GM four pin. But you solved my dilemma, thank you! |
