It is currently Tue Nov 17, 2026 8:06 am
PostPosted: Mon Apr 17, 2006 4:41 pm
I just brought home a '72 Duster and it looks like it has 5 on 4" center wheels. I am going to replace the 7 1/4" rearend with an 8 3/4" and rebuild the front end with disc brakes. What pattern rear end do I need to have matching wheels front and rear?
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Mon Apr 17, 2006 4:56 pm
5X4 1/2 Is what is normally run.
70 Dart, 360, 727
PostPosted: Mon Apr 17, 2006 5:21 pm
That depends on which disc brakes you install ('65-'72 4-piston items have 4" bolt circle; '73-up single-piston types have 4½"), and upon whether you get an A-body 8¾" or obtain and modify a B-body unit. The A-body 8¾" rears have 4" bolt circle; B-bodies have 4½".
PostPosted: Mon Apr 17, 2006 5:44 pm
/slaps head. I forgot about the A body 8 3/4. Measure the studs to see what you have.
70 Dart, 360, 727
PostPosted: Mon Apr 17, 2006 6:54 pm
My understanding is that all a-body 8 3/4 rear ends have the 4" bolt circle. To get the 4 1/2 you will have to get your axles redrilled or get some custom axles.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
Users browsing this forum: Amazon [Bot] and 1 guest
