Valve angle question
https://slantsix.org/forum/viewtopic.php?t=17045
Author:  skraecken [ Fri Apr 14, 2006 1:05 am ]
Post subject:  Valve angle question
Has there been any changes in valve angles, depending of the year of the engine?
Author:  SlantSixDan [ Fri Apr 14, 2006 7:40 am ]
No.
Author:  skraecken [ Fri Apr 14, 2006 10:51 am ]
Then when I got a head with 2 exhaustvalves that got 50 degr. Somebody have done a bad valvejob. The rest is 45 degr.
Author:  SlantSixDan [ Fri Apr 14, 2006 11:25 am ]
Yep, sounds like someone was too far into the Aquavit when doing that valve job :-)
Author:  Thropar [ Fri Apr 14, 2006 11:40 am ]
Post subject:  Vj
You can grind the seats and valve faces to anything you want (within reason). Some people cut the valve face at 44, and the seats at 30/45/60 where the 45 is the area being hit by the valve. Some people cut the valve face at 2 angles (back-cut) and the seat at 5 angles. It varies, depending on the builder.
But for most stock applications, it's a 45 on both. A mismatched angle on the same head is a mistake. (slipped adjuster on valve machine OR more likely, a very worn 45 stone...are the 50's on one end of the head?)
Author:  skraecken [ Sat Apr 15, 2006 12:08 am ]
They are on cyl 3 and 4, these valves have been changed at some time, they are the "early" type with 3 (or 4) groves, all the others got 2.
Author:  Thropar [ Sat Apr 15, 2006 9:56 am ]
Post subject:  valves
Seems like the two were done as a "fix" to the head and not a complete valve job. As long as the seat and valve face match, it'll work, but I'd say get them all re-cut to match.
