Hypper-pak alternative?
https://slantsix.org/forum/viewtopic.php?t=17080
Page 1 of 2
Author:  Reed [ Sat Apr 15, 2006 3:21 pm ]
Post subject:  Hypper-pak alternative?
I will be intalling an Offy intake on my van soon, and came across an interesting product by Offy:
This is supposed to be a bolt-on cross-ram simulator. I want to try this on my van since I can't run a hyper-pak. Do you think it will actually help create a ram effect if I mount it so that the carb sits over towards the passenger side of the van?
Author:  Rust collector [ Sat Apr 15, 2006 4:00 pm ]
No idea, but I would run it just because!
Is it expensive?
Author:  Reed [ Sat Apr 15, 2006 4:29 pm ]
It costs about $140 as pictured.
Author:  SlantSixDan [ Sat Apr 15, 2006 4:59 pm ]
Wow, what a bizarre product! Is it new, or another old treasure that Offy's had catalogued forever? What's the Offy P/N?
(If I had one of these, I'd probably be completely perverse and use it with a 2bbl adaptor plate! :shock: )
Author:  WhaleMstr [ Sat Apr 15, 2006 6:33 pm ]
:D :shock: :D :D :D
What HE said!!!
Author:  WhaleMstr [ Sat Apr 15, 2006 6:35 pm ]
Only I'd get it backwards!
Author:  Reed [ Sat Apr 15, 2006 6:50 pm ]
Actually, that is exactly what I am going to do! I will be running a BBD first, but eventually I am going to run a staged Holley 2305.
These are being sold new through a website:
http://www.offyparts.com/product_info.p ... f1a3eae86d
It is four inches tall and 13 inches long, which would rule it out for a normal car application (unless you didn't have a hood), but it will fit fine under the doghouse in a van!
Author:  sandy in BC [ Sat Apr 15, 2006 7:01 pm ]
I thought you had a hyperpac?
Author:  WhaleMstr [ Sat Apr 15, 2006 7:01 pm ]
COOL!
I want 3!!!
:lol:
Author:  DusterIdiot [ Sat Apr 15, 2006 7:07 pm ]
Post subject:  Not anymore...
It wouldn't fit in the van, so he sold it to me a while back...it currently is at CPM being machined for an EFI setup...
Author:  emsvitil [ Sat Apr 15, 2006 7:57 pm ]
I can't see how it would work extending the runners into a ram effect........
It's a big open volume (offset to look cool), so all it would do is increase plenum volume.................
Author:  emsvitil [ Sat Apr 15, 2006 7:58 pm ]
Plus you're doing 2 more 90 degree turns of the air flow, that can't be good............
Author:  Reed [ Sat Apr 15, 2006 8:21 pm ]
So the 90 degree bends will hurt airflow and the ram effect won't happen due to the open area?
I thought that the ram effect simply had to do with the volume of air moving into the cylinder due to inertia. I don't know much about intake manifold design, so any comments would be appreciated.
Author:  panic [ Sat Apr 15, 2006 8:36 pm ]
Exactly.
Page 1 of 2 All times are UTC-07:00
