| Lower control arms at different angles - which one is bent? https://slantsix.org/forum/viewtopic.php?t=17095 |
| Author: | sixsignet [ Sun Apr 16, 2006 2:55 pm ] |
| Post subject: | Lower control arms at different angles - which one is bent? |
If I put straight edges (parallel to driveshaft) on the bottom of both LCAs, they are at different angles. I suspect one is bent, but which one? Is there some measurement I can make to determine which one is bent? Is there some reference line the straight edges should be parallel to? Driveability seems fine. I am getting ready to rebuild the front end and want to replace any bent stuff... |
