| Bolt Circle for 8 3/4 Rearend? https://slantsix.org/forum/viewtopic.php?t=17109 |
| Author: | bwhitejr [ Mon Apr 17, 2006 4:41 pm ] |
| Post subject: | Bolt Circle for 8 3/4 Rearend? |
I just brought home a '72 Duster and it looks like it has 5 on 4" center wheels. I am going to replace the 7 1/4" rearend with an 8 3/4" and rebuild the front end with disc brakes. What pattern rear end do I need to have matching wheels front and rear? bwhitejr |
| Author: | Lars [ Mon Apr 17, 2006 4:56 pm ] |
5X4 1/2 Is what is normally run. |
| Author: | SlantSixDan [ Mon Apr 17, 2006 5:21 pm ] |
| Post subject: | Re: Bolt Circle for 8 3/4 Rearend? |
Quote: I just brought home a '72 Duster and it looks like it has 5 on 4" center wheels. I am going to replace the 7 1/4" rearend with an 8 3/4" and rebuild the front end with disc brakes. What pattern rear end do I need to have matching wheels front and rear?
That depends on which disc brakes you install ('65-'72 4-piston items have 4" bolt circle; '73-up single-piston types have 4½"), and upon whether you get an A-body 8¾" or obtain and modify a B-body unit. The A-body 8¾" rears have 4" bolt circle; B-bodies have 4½".
| Author: | Lars [ Mon Apr 17, 2006 5:44 pm ] |
Quote: Quote: I just brought home a '72 Duster and it looks like it has 5 on 4" center wheels. I am going to replace the 7 1/4" rearend with an 8 3/4" and rebuild the front end with disc brakes. What pattern rear end do I need to have matching wheels front and rear?
That depends on which disc brakes you install ('65-'72 4-piston items have 4" bolt circle; '73-up single-piston types have 4½"), and upon whether you get an A-body 8¾" or obtain and modify a B-body unit. The A-body 8¾" rears have 4" bolt circle; B-bodies have 4½". |
| Author: | dakight [ Mon Apr 17, 2006 6:54 pm ] |
My understanding is that all a-body 8 3/4 rear ends have the 4" bolt circle. To get the 4 1/2 you will have to get your axles redrilled or get some custom axles. |
