It is currently Wed Nov 25, 2026 12:17 am
PostPosted: Mon Apr 17, 2006 10:11 pm
i have had recent trouble with my engine dying out when put in gear and steppin on the gas , car seems to idle fine but when i put it in gear and step on the gas it usually wants to bog out, and occasionally die when coming to a stop. engine will also want to die out when throttle is hit to quickly- in gear. any help or suggestions are appreciated , thanks
225 cid-1bbl carb
PostPosted: Tue Apr 18, 2006 12:12 am
when was the last time you adjusted the valves? that's probaly last on the list, but it does help. next, adjust your carb, timing. or rebuild.
70 Plymouth Valiant 4dr
PostPosted: Tue Apr 18, 2006 5:11 am
Sounds, to me, like the accelerator pump in the carb is not working, properly.
PostPosted: Tue Apr 18, 2006 5:12 am
Car Model: 1974 W100; 72 Dart
i'd check things like the fuel filter, timing, plugs/plug wires, dwell. basically a real complete tune up, set your air idle screw with a vacuum gauge. if you have uneven idle or miss that goes away with rpms, check your valve lash and correct as needed.
while doing all this you can check over the carb...look for leaky gaskets, check accelertor pump function that sort of thing. let us know how it goes.
sb
PostPosted: Tue Apr 18, 2006 8:16 am
I had this same problem a few months ago. It wound up being a loose carb base plate. Every time I'd put the car in gear, too much air would get in and lean the carb out until it died.
Duster Idiot showed me a good way to check for leaks. Take off your air cleaner and just spray some carb cleaner/starter around where the gaskets/seals are and if the car revs up then whatever gasket or seal you are spraying by is probably got a leak.
1973 Dart Swinger Super 6 with 71k
1976 Datsun 280ZX with Mopar I-6
PostPosted: Tue Apr 18, 2006 8:39 am
Put your hand over the top of the air cleaner, blocking it off. It should die immediately. If it keeps on chugging, you have got a vacuum leak.
82 D150-225/727
02 Dakota-3.9/5 speed
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot], Google [Bot] and 10 guests
