It is currently Wed Nov 25, 2026 2:19 am
Post new topic  Reply to topic  [ 26 posts ]  Go to page 1 2 Next
 Post subject: Hypper-pak alternative?
PostPosted: Sat Apr 15, 2006 3:21 pm
I will be intalling an Offy intake on my van soon, and came across an interesting product by Offy:
This is supposed to be a bolt-on cross-ram simulator. I want to try this on my van since I can't run a hyper-pak. Do you think it will actually help create a ram effect if I mount it so that the carb sits over towards the passenger side of the van?
PostPosted: Sat Apr 15, 2006 4:00 pm
No idea, but I would run it just because!
Is it expensive?
PostPosted: Sat Apr 15, 2006 4:29 pm
It costs about $140 as pictured.
PostPosted: Sat Apr 15, 2006 4:59 pm
Wow, what a bizarre product! Is it new, or another old treasure that Offy's had catalogued forever? What's the Offy P/N?
(If I had one of these, I'd probably be completely perverse and use it with a 2bbl adaptor plate! :shock: )
PostPosted: Sat Apr 15, 2006 6:33 pm
:D :shock: :D :D :D
What HE said!!!
PostPosted: Sat Apr 15, 2006 6:35 pm
Only I'd get it backwards!
PostPosted: Sat Apr 15, 2006 6:50 pm
Actually, that is exactly what I am going to do! I will be running a BBD first, but eventually I am going to run a staged Holley 2305.
These are being sold new through a website:
http://www.offyparts.com/product_info.p ... f1a3eae86d
It is four inches tall and 13 inches long, which would rule it out for a normal car application (unless you didn't have a hood), but it will fit fine under the doghouse in a van!
PostPosted: Sat Apr 15, 2006 7:01 pm
I thought you had a hyperpac?
COOL!
I want 3!!!
:lol:
 Post subject: Not anymore...
PostPosted: Sat Apr 15, 2006 7:07 pm
It wouldn't fit in the van, so he sold it to me a while back...it currently is at CPM being machined for an EFI setup...
PostPosted: Sat Apr 15, 2006 7:57 pm
I can't see how it would work extending the runners into a ram effect........
It's a big open volume (offset to look cool), so all it would do is increase plenum volume.................
PostPosted: Sat Apr 15, 2006 7:58 pm
Plus you're doing 2 more 90 degree turns of the air flow, that can't be good............
PostPosted: Sat Apr 15, 2006 8:21 pm
So the 90 degree bends will hurt airflow and the ram effect won't happen due to the open area?
I thought that the ram effect simply had to do with the volume of air moving into the cylinder due to inertia. I don't know much about intake manifold design, so any comments would be appreciated.
PostPosted: Sat Apr 15, 2006 8:36 pm
Exactly.
Users browsing this forum: Google [Bot] and 7 guests
