Speedo cable?
https://slantsix.org/forum/viewtopic.php?t=17153
Author:  Luthastro [ Thu Apr 20, 2006 10:16 am ]
Post subject:  Speedo cable?
Are there several speedo cables (not just the core) on the /6's or are all the same?
Author:  65dart [ Thu Apr 20, 2006 10:23 am ]
It depends on your year. If your car is 1966 or newer they should be fairly interchangeable. Pre 1966 uses a different system.
Author:  Luthastro [ Thu Apr 20, 2006 12:37 pm ]
So within a given year I wouldn't find a cable for an automatic trans different from one for a manual, or some such thing. Thanks.
But if I put a '71 trans in my '65 I would have a speedo cable problem?
Author:  kesteb [ Thu Apr 20, 2006 10:46 pm ]
Yes, you would have to use a '66 speedo cable. The '66 has the correct end for the '71 trans and the correct end for the '65 speedometer.
It also works great for aftermarket mechanical speedometers.
Author:  Luthastro [ Fri Apr 21, 2006 7:19 am ]
Thanks. All these details help.
Author:  Luthastro [ Fri Apr 21, 2006 3:35 pm ]
What's the best way to lube a speedo cable? Obviously grease can go hard on you. Someone told me graphite was best. That would, of course, assume knowing how to clean out the old stuff.
Author:  Jeb [ Fri Apr 21, 2006 6:47 pm ]
Whenever the cable on my Duster gets noisy I squirt some liquid wrench down it, which contains graphite. Graphite in the tube works pretty good too.
Author:  Luthastro [ Fri Apr 21, 2006 10:11 pm ]
Thanks. Does all Liquid Wrench contain graphite or do you have to search out a specific kind?
Author:  Jeb [ Sun Apr 23, 2006 6:13 pm ]
The kind in the yellow can is what I use. Go to your local hardware store and look around at the lubricant section. I think they make graphite in a spray can now.
Author:  65 dartman [ Sun Apr 23, 2006 6:23 pm ]
kesteb"]Yes, you would have to use a '66 speedo cable. The '66 has the correct end for the '71 trans and the correct end for the '65 speedometer.
IIRC a 67 speedo cable will also work correctly
Author:  KBB_of_TMC [ Wed Apr 26, 2006 10:39 am ]
Post subject:  speedo cable
I'm pretty sure that '67 A-bodies used the screw-on speedometer, while '68 went to the clip.
Cruise control cars use a 2-piece cable. I've had good luck lubing the cable by **gently** pulling the core out, wiping it off, and lubing it with graphite-impregnated speedometer cable grease (black oily stuff) as I inserted it back into the housing. I also tried Lubriplate white grease with good results.
In my '74 Coronet, the core came out toward the cruise control - when I pulled it the wrong way it stretched some and then tended to bind - I used a Dremel tool 409 cutting wheel to shorten it by 1/8" and all was fine again.
Author:  Luthastro [ Wed Apr 26, 2006 12:55 pm ]
Post subject:  Re: speedo cable
Did that binding cause the needle to bounce?
Author:  KBB_of_TMC [ Thu Apr 27, 2006 9:14 am ]
Post subject:  speedometer cable
Yes- binding made my needle bounce +/-20mph or so. The cable core is a long spiral spring, but if you stretch it by pulling it the wrong way (as I did - only about 5-10 lb's worth) it doesn't quite return to the proper length again.
You can test it by loosening the nut or clip behind the speedometer to get an extra ~1/8-1/4" play and see if the bouncing stops. If that's the case, you need to shorten the cable by just a little.
The Dremel 409 blade is a thin abrasive disk that makes a very clean cut through the steel core - wear protective googles, as it is very easy to shatter the blade and pieces fly off at high speed. You can then use it to slight round off any rough edges before you put the cable back in too.
Sears often puts their (Dremel) tools on sale; they are not expensive and come in very handy.
I find that the I need an AC powered one for good cutting. The 2 tips I use most of the time are the little wire brushes and the abrasive cutting disks. The #409 disk is only a little stronger than a potato chip, so I'm not kidding about absolutely needing eye protection!
Author:  stuggin [ Thu Apr 27, 2006 5:13 pm ]
What's the deal with pre 66 cables? mine just broke
Allen
