It is currently Mon Nov 23, 2026 6:38 pm
PostPosted: Fri May 05, 2006 6:10 am
Just to remember because I´m pretty bad making carburations, to make the mixture lean (minus gas use), the mixture screw must be bolt in right?, if you unbolt it, it makes the mixture rich (more gas use).
Sorry for this kind of stupid questions, but I really know nothing about carbs.
Mopar Muscle is well defend by Slant Six!
Valiant Duster 1971
PostPosted: Fri May 05, 2006 7:34 am
Not a stupid question! You're right: Turn the mixture screw clockwise (inward) and you make the mixture leaner—less gas. Turn it anticlockwise (outward) and you make the mixture richer—more gas.
PostPosted: Fri May 05, 2006 9:55 am
Thanks Dan!
Valiant Duster 1971
