| Concealment plug removed -holley 1945 https://slantsix.org/forum/viewtopic.php?t=17227 |
| Author: | Slant n' Rant [ Mon Apr 24, 2006 10:31 pm ] |
| Post subject: | Concealment plug removed -holley 1945 |
I realize that this plug is not INTENDED to ever to be removed as idle mixture is factory set however it WAS at some time or another. It appears that it was removed properly but for what reason is anybodys guess ( the van spent alot of time south-of-the-border Mexico way). I was told the 90+ year old lady owner had this van converted, had been from Toronto, Canada to Mexico frequently. I would surmize that with long hot travel south then coming back to cold city driving she experienced drivability problems? Maybe her mechanic (or dealership) thought it was the way to go at that time i dont know. I feel its going toward the rich side since even with tune up it still boggs, although slight and the mileage could be better ( I know not to expect too much from that however, ESA and all) My question CAN I lean this out if the mood strikes and with what tool ( I can't poke my head in far enough to see) or leave it and compensate in other areas to counteract the rich setting (timing etc)? |
| Author: | Dennis Weaver [ Tue Apr 25, 2006 7:47 am ] |
OH MY GOD, THE PLUG IS REMOVED FROM YOUR 1945 HOLLEY?!? YOU HAVE TO TURN IT OVER TO THE FEDERAL GOVERNMENT SO THEY CAN GET THE CIA, FBI, EPA, CPSC, OSHA AND THE BOMB SQUAD TO COME BLOW IT UP WITH C4 EXPLOSIVE BEFORE IT HARMS ONE SINGLE MORE CITIZEN! D/W P. S. - I bet you remove the "do not remove" tag from matresses too, you scofflaw, you. |
| Author: | Slant n' Rant [ Tue Apr 25, 2006 11:51 am ] |
Funny, youre missing the point. If someone removed it in order to ADJUST it from factory tune so if its running rich then why the hell would I not try to lean it out. Im not the blowhard ( dealership for sure) who removed it in the first place just want to know what tool to jamb in there |
| Author: | Dennis Weaver [ Tue Apr 25, 2006 12:23 pm ] |
Quote: Funny, youre missing the point. If someone removed it in order to ADJUST it from factory tune so if its running rich then why the hell would I not try to lean it out. Im not the blowhard ( dealership for sure) who removed it in the first place just want to know what tool to jamb in there
Dude... Lighten up! It was a joke D/W |
| Author: | R/T Magnum [ Tue Apr 25, 2006 12:28 pm ] |
I don`t think I have ever seen a 1945 with a plug |
| Author: | Super6 [ Tue Apr 25, 2006 1:05 pm ] |
IIRC you need a 3/32" allen wrench. Size may be off though.... |
| Author: | Reed [ Tue Apr 25, 2006 2:41 pm ] |
Quote: IIRC you need a 3/32" allen wrench.
Sounds about right to me. It will be either a small flathead screwdriver or an allen wrench.
| Author: | Slant n' Rant [ Tue Apr 25, 2006 3:43 pm ] |
from one D/W to another D/W ( Dan Weber) I know it was a joke but im a crank when I dont have that first coffee dont ya know? I thought i seen a hex way in there but I wasnt in a rush to go poking in there if somebody knew better. thank you |
| Author: | Jeb [ Tue Apr 25, 2006 5:13 pm ] |
Do yourself a favor and start looking for either a Carter BBS, Holley 1920, or a Supersix setup. Holley 1945's are junk. I have one on my truck and used to have one on my car and they both are piles of crap. They flow poorly, are set up way to lean, jets are a pain to change, power valve channel is way to restritctive, and they are the smallest carbs used on a 225. |
