| What does it mean when a push botton gets stuck in the down? https://slantsix.org/forum/viewtopic.php?t=17284 |
| Author: | HookedByA62Valiant [ Thu Apr 27, 2006 6:57 pm ] |
| Post subject: | What does it mean when a push botton gets stuck in the down? |
HI, I'm new to Mopars and am having lots of fun with a 62 Valiant, (added bucket seats, Super Six set up and electronic ignition). And out of the blue, I pushed the reverse button in and it won't come back up. What's that all about? Thanks, Mike |
| Author: | VDART [ Thu Apr 27, 2006 7:44 pm ] |
| Post subject: | push button |
hopefully the plastic lever just came out of the prongs that hold it into the switch selector--Take the dash cover off & use a light source to check & see exactly what happened.. if nothing is broke just line it back up & push it back in place--- you might want to squeeze the prongs together just a little to help hold them-- (if they do not hole the lever tight) Good luck |
| Author: | relic-lover [ Thu Apr 27, 2006 8:03 pm ] |
| Post subject: | weak spring |
On my daughter's 61 it was a broken spring in the push button box. It was part of the mechanism that was supposed to put the R button back to the front when N was pushed. I bought a 63 dart button box and used the spring from it as much of the innards were the same. I would guess that a hard to move (dirty or kinked) shift cable might also have the same affect. |
| Author: | HookedByA62Valiant [ Fri Apr 28, 2006 7:14 am ] |
| Post subject: | Thanks folks |
I will look into this tonight and let you know !!! |
| Author: | stuggin [ Fri Apr 28, 2006 1:18 pm ] |
cool, i guess i gotta take that box out and have a look too, my Neutral button's stuck Allen |
| Author: | HookedByA62Valiant [ Sun Apr 30, 2006 5:36 pm ] |
| Post subject: | Fixed !!!!!!!!!!! |
Everyone was right, the reverse button slipped out of the connector. I remated the two and it works fine again. THANKS |
